01-07-2025 01:55 AM
Hi everyone,
I need your help to reset the password of several users under certain conditions, for this I have created a flow that will be executed only once and I have used the “Update password” action, using the script section of the action I have added the following script to create an encrypted password formed by the first and last name of the user plus a random number, and then add the password to the body of an email to send to each user. The flow returns this error “Error: password must not be empty (sys_script_include.c2bb80aa73126300039a2ea3c4f6a721.script; line 20)”. Any ideas?
Thank you very much and best regards.
var first_name = inputs.first_name;
var last_name = inputs.last_name;
var randomNumber = Math.floor(Math.random() * 1000);
var password = first_name + last_name + randomNumber;
var encr = new GlideEncrypter();
var encryptedPassword = encr.encrypt(password);
outputs.encryptedPassword = encryptedPassword;
gs.info('First name: ' + first_name);
gs.info('Last name: ' + last_name);
gs.info('Generated password: ' + password);
gs.info('Encrypted password: ' + encryptedPassword);
})(inputs, outputs);
01-07-2025 07:35 AM
Hi Tomas.
I tried in a Background script , its something like this. But I am not convinced of the way in which you are proposing, as it may incur in error, but if it is as indicated I recommend that you pass in an email the password if the user to avoid sending confidential information.
*** Script: First name: John
*** Script: Last name: Doe
*** Script: Generated password: JohnDoe991
*** Script: Encrypted password: KNXvgcvr3QBKrGjyHNEceg==
01-08-2025 05:20 AM
what's the solution for this question?
