‎01-31-2023 10:25 PM
I have a requirement where there are 2 levels of approvers. If the first level approver either approves or rejects the state changes respectively. Same goes with second level approver. If the first level does not respond for 2 days it should go to 2nd level approver. I have designed a flow using the due date field in ask approval section. So after triggering a second level approver, the first level approver states goes to no longer required. Our requirement is something like, even though second level approval has been triggered the first level approval state still needs to be in requested state so that the first level approval still has the access to approve it after 2 days of waiting.
Any help would be appreciated.
Thanks & Regards
Supritha
‎02-01-2023 11:25 PM
Add flow logic - "Do the following in Parallel"
Add Action "Ask for Approval" in one node
Add Flow logic "Wait for a duration of time" on other node
Add Action after wait "Ask for Approval"
Bharath
‎02-01-2023 01:02 AM
Hello @Nagula Supritha ,
1- Are you using flow designer or Workflow to achieve this?
2-If you are using workflow then go to workflow editor and open the workflow which is you are using.
3-Click on the first approver , where you have applied the criteria of waiting for 2 day and then move to next approver.
4-Go down you can see the scripts where you have to comment the no longer required line from that code .
5-By doing this it will trigger for 2nd approver but the first approver is still able to approve.
Kind Regards,
Abhishek Rai
‎02-01-2023 04:43 AM
‎02-01-2023 09:55 PM
Can you please attach any snapshot to get the clear picture of the issue.
Thankyou
‎02-06-2023 03:30 AM
Hi @AB1998
I used due date functionality in my requirement. Below is the screenshot. So after that due date added 2 conditions:
1. If the due date is not cancelled then it should update the record.
2. If the due date is cancelled, then it should trigger a second level approver. Here after triggering 2nd level approver the 1st level is going to 'No longer required'.
‎02-11-2026 03:45 AM
can u add screenshots for the below ..i m not able find due date in if condition
