Need help in scripting to push unique values in array
shaik_irfan
I have a script which is on inbound action that takes the subject and search for a keyword and get the knowledge article number and push into an array. Which is working fine
But if in case i have duplicate keywords then it is pushing the kb number multiple times. how to push only unique number
var arr = [];
var substring = email.subject;
substring = substring.split(" ");
for(var i=0; i<substring.length; i++){
if(substring[i] != " "){
var kn = new GlideRecord('kb_knowledge');
kn.addEncodedQuery('metaLIKE'+substring[i]);
kn.query();
if(kn.next()){
	gs.log('Found kb');
	checked = 'true';
	var url = '/sp?id=kb_article&sys_id=' + kn.sys_id;
	var com = '[code]<a href="' + url + '" target="_blank" >' + gs.getMessage(kn.number) + '</a>[/code]';
	com += "\n";
	arr.push(com);
If i send the subject as "I have issue with my computer" then i get one article like KB0000002
If i send the subject as "My Computer is not working, i already troubleshooted my computer" then i get result in my array as KB0000002, KB0000002
Since i found the Computer keyword twice i get kb number twice but i want to display only once
Can anyone please help me how to do this
Mwatkins
Hm... you want to avoid the same KB twice, right? So you need the unique check on the "arr" array to see if a given KB is already in it. I think I'd do it like this:
if (arr.indexOf(kn.number) == -1)
arr.push('[code]<a href="' + url + '" target="_blank" >' + gs.getMessage(kn.number) + '</a>[/code]');
Thanks Muhammad for the catch.
Updated the script. Happens many times when we don't test the code at our end & provide a solution.
Yeah, Agree :')
Muhammad
Mwatkins
@Mwatkins
A slight change made the trick
if (arr.toString().indexOf(kn.number) == -1)
