Not able to close problem records
Raviteja K
Assigned person not able to   close problem record, in spite related problem tasks are closed complete.
Can you include current.setWorkflow(false); before current.update(); for testing purpose and check once.
18 REPLIES 18
I suspect somewhere there is a script include or something (possibly TaskStateUtil) that is defining certain state numbers to be declared "inactive" states. By default this is 3, 4, and 7. Yours may have been tweaked to recognize 6 as an inactive state.
This is going to take some more digging.
u_problem_task is the right table
Two things
First, I'd change the second query line from
ptasks.addQuery('u_problem_task_state', 1);
to
ptasks.addQuery('active', true); // Assuming your table u_problem task is extended from task or problem_task.
Second, for testing, put the following line right after your ptasks.query() line
gs.addInfoMessage(ptasks.getRowCount() + ' open records found');
I will try
