Please help with Flow Designer Inline Script Issue.
03-25-2024 11:27 AM
I created a custom table with one URL field type. The below inline script generate a URL and inserted it into the custom table. However, the URL that is showing in the custom table looks like this. Thank you
Example:
I would like to display it as the text "
1. Here is the Flow Designer Inline Script:
03-25-2024 03:38 PM
Where are you adding it?
It works on work notes. But not on a text field.
03-25-2024 04:17 PM
I have tried changed the field type to 'String' and also "html", but still it did not work.
03-26-2024 11:31 AM - edited 03-26-2024 11:31 AM
Yes...it wont work for a string or URL field.
In URL field you can only post an URL. But if you need a label, you will need to use HTML. And then use following code to populate it. But I am not sure, if it is worth since html field consume more space of a record. I would use URL field, if the customer agrees to just display the url.
03-27-2024 09:58 PM
Hi @SanjivMeher
Thank you for continue to help!
I change the field type to "HTML" and it is still not displaying the label:
03-28-2024 11:02 AM
In the list view it will show HTML...But in form view does it show the link properly?
