Plugins required for MIM workbench.
AnkitK832453164
Hi Team,
Could you help me with the list of all plugins required to setup MIM Workbench.
And whether those plugins are free or paid.
Ehab Pilloor
Hi @AnkitK832453164,
You can activate the Incident Management - Major Incident Management plugin (com.snc.incident.mim) if you have the admin role. This plugin includes demo data and activates related plugins if they are not already active.
Before you begin
Role required: admin
About this task
Incident Management - Major Incident Management plugin (com.snc.incident.mim) must be manually activated for new and existing customers.
Incident Management - Major Incident Management plugin activates these related plugins if they are not already active:
  • Incident Communications Management (com.snc.iam)
  • Incident Updates (com.snc.incident.updates)
  • Task-Outage Relationship (com.snc.task_outage)
Additional plugins for Incident Management - Major Incident ManagementPlugin Description
Notify
[com.snc.notify]
Provides platform features for workflow-driven voice calls, conference calls, and SMS messages. Requires the Twilio Direct Driver and a separate contract with Twilio for SMS and Voice capabilities.
Note: Existing users already using Twilio Driver need to migrate to Twilio Direct Driver.
On-Call Scheduling
[com.snc.on_call_rotation]
Provides the ability to create on-call schedules and escalation trees. When an incident is created, dynamically route the escalation to an on-call resource. On-Call Scheduling enables you to configure and build different on-call schedules per process and assignment group.
Procedure
  1. Navigate to All > System Applications > All Available Applications > All.
  2. Find the plugin using the filter criteria and search bar.
    You can search for the plugin by its name or ID. If you cannot find a plugin, you might have to request it from ServiceNow personnel.
  3. Select Install to start the installation process.
    Note: When domain separation and delegated admin are enabled in an instance, the administrative user must be in the global domain. Otherwise, the following error appears: Application installation is unavailable because another operation is running: Plugin Activation for <plugin name>.
    You will see a message after installation is completed. For information about the components installed with a plugin, see Find components installed with an application.
Ref: https://www.servicenow.com/docs/bundle/yokohama-it-service-management/page/product/incident-manageme...
Ehab Pilloor
sundarjm
Hi @AnkitK832453164
I believe the following plugin are enough for MIM workbench,
1)com.snc.incident.mim   2)com.snc.incident.min.workbench
Also please validate these two plugin in system definition > plugins before you go to store
 If this solves your issue, please mark it as Correct.
Dr Atul - LNG
Hi @AnkitK832453164
No additional plugin is required for MIM Workbench. Once you activate the MIM plugin, it gets enabled automatically. It is free plugin but to use it a user need a MI Manager role.
https://youtu.be/SW_ZacFHT34
OOTB Demo of ServiceNow Major Incident Management Process LinkedIn:https://www.linkedin.com/in/atulgroverservicenowconsultant Redistribution or copying of functionality is not allowed!
