Restrict Problem management module with out using ACL
Mounika30
restrict Problem management module with out using ACL
1. Only problem manager and incident manager can view/edit problem module.
2.ITI fulfiller can only view/edit problem tasks that are specifically assigned to them.
How to achieve this?
Dr Atul - LNG
Hi @Mounika30
Either create a Business Rule (BR) or provide a module-specific rule, such as...
Viraj Hudlikar
Tera Sage
Hello @Mounika30
Have you given a try for it? What kind of blocker you are facing on this?
For 1 you can add roles in module settings who should be able to view & edit.
For 2 you can write a Display BR which will check if login user is assigned to user over prb record then only showcase record and allow to edit.
Thanks & Regards
Viraj Hudlikar.
Ankur Bawiskar
@Mounika30
My thoughts
-> even if you hide the problem module the users can navigate to problem.LIST and view or edit
a) ensure you update the correct ACLs
-> for 2nd point you can use query business rule, what did you start and where are you stuck?
for second point I have implemented this but it is not wrokingInsert, update and query  BR.png
