Script to capture priority input from record producer and show in incident table
FaizDev101
3 ACCEPTED SOLUTIONS
@FaizDev101 try this
if(producer.priority == '1 - Critical'){//priority variable choices  1 - Critical "value"
current.impact =1;
current.urgency = 1;
}else if(producer.priority == '2 - High'){/priority variable choices  2 - High "value"
current.impact = 1;
current.urgency = 2;
}else if(producer.priority == '3 - Moderate'){/priority variable choices  3 - Moderate "value"
current.impact = 2;
}else if(producer.priority == '4 - Low'){/priority variable choices  4 - Low "value"
current.impact = 2;
current.urgency = 3;
}else if(producer.priority == '5 - Planning'){/priority variable choices  5 - Planning "value"
current.impact = 3;
check one thing in priority variable choices  "value" should be given above in "if" and "else if"
If my inputs have helped with your question, please mark my answer as accepted solution, and give a thumb up.
Bharath Chintala
FaizDev101
I used this code and it is working Thank you so much.
if(producer.priority == 1){
current.impact = 1;
}else if(producer.priority == 2){
current.impact = 1;
}else if(producer.priority == 3){
current.impact = 1;
current.impact = 2;
current.impact = 2;
}else if(producer.priority == 4){
current.impact = 2;
current.impact = 3;
current.impact = 3;
}else if(producer.priority == 5){
current.impact = 3;
@FaizDev101  you don't need to each number that many times each priority number once is enough
Replace this
current.impact = 1;
current.impact = 1;
current.impact = 2;
current.impact = 2;
current.impact = 3;
Bharath Chintala
current.impact =1;
current.impact = 1;
current.impact = 2;
current.impact = 2;
current.impact = 3;
Bharath Chintala
FaizDev101
current.impact = 1;
current.impact = 1;
current.impact = 1;
current.impact = 2;
current.impact = 2;
current.impact = 2;
current.impact = 3;
current.impact = 3;
current.impact = 3;
Replace this
current.impact = 1;
current.impact = 1;
current.impact = 2;
current.impact = 2;
current.impact = 3;
Bharath Chintala
