Urgent help for script
servicenow_devo
Business rule is created for state change in sc task request for based on journal entry change made by non assignment group members. Worknote is update on script to highlight this development. But when members update work note this work note abd worknote added via script is comming in same line. Worknote is script mentioned as updated by system..
Worknote added by agent to update as separate entry with user name
Thankyou
Hi @servicenow_devo
Can you please share a snip of the worknotes if possible and your script to debug it further ?
Thanks & Regards
Amit Verma
Thanks and Regards
Amit Verma
Rajdeep Ganguly
Mega Guru
Here are the steps to implement this:
1. Create a new Business Rule on the sc_task table.
2. Set the 'When to run' section as follows:
- When: before
- Insert: unchecked
- Update: checked
- Delete: unchecked
- Query: unchecked
3. In the 'Advanced' section, write a script to check if the work_notes field has been updated and if the user is not a member of the assignment group. If these conditions are met, add a new line to the work_notes field and append the new work note. Here is a sample script:
javascript
// Check if work_notes has been updated and if the user is not a member of the assignment group
if (current.work_notes.changes() && !current.assignment_group.contains(gs.getUserID())) {
// Add a new line to the work_notes field and append the new work note
current.work_notes = "\n" + current.work_notes;
})(current, previous);
4. Save the Business Rule.
This script checks if the work_notes field has been updated and if the user is not a member of the assignment group. If these conditions are met, it adds a new line to the work_notes field and appends the new work note. This should ensure that work notes added by agents are updated as separate entries with the user name.
nowKB.com
For asking ServiceNow-related questions try this :
For a better and more optimistic result, please visit this website. It uses a Chat Generative Pre-Trained Transformer ( GPT ) technology for solving ServiceNow-related issues.
Link - https://nowgpt.ai/
For the ServiceNow Certified System Administrator exams try this :
https://www.udemy.com/course/servicenow-csa-admin-certification-exam-2023/?couponCode=NOW-DEVELOPER
