when incident priority is p5 , problem priority is also same ,but need to change.
surya65
Hi Team,
i have incident priority are: 1 to 5.
problem priority are :1 to 4.
when i  cretaed the incident with priority p5, and i created the problem through incident ,and
priority of the problem is same has incident p5.
but in the problem form, under priority drop down i have 1 - 4,
soo need to change when the incident  priority is p5, when problem priority should be p4. only.
in my case its showing p5.
how can i achive this any helps,
thanks,
surya.
20 REPLIES 20
Got it. thanks for posting the screenshot. My Apologies there were some changes which was there in my Personal instance and hence it caused the confusion.
Solution:
Steps mentioned above remains same . No changes in that.
Only Change: Instead of Source Incident the correct field should be "First Reported By".
Sharing the Business Rule screenshot again for reference to avoid any confusion:
BR Details:
Table name: Problem:
When: Before Insert
Condition: First Reported By is not empty
First Reported By is Not empty AND First Reported By.Number Starts with INC
Script:
	// Add your code here
	if(current.priority == 5){
		current.urgency =2;
		current.priority = 4;
})(current, previous);
Business Rule screenshot for reference below:
Please note you can refer the steps on how to reach to Number field in second condition where it's written starts with. Details for this shared above . If having an issue do let me know.
This should definitely work for you.
Result:
Shloke
