When Yes/No field changes from Yes to No - Clear values selected in a list collector
SMuir
Giga Guru
I have a Catalog Item with a Yes/No Field
If Yes is selected
The UI policy will show a List collector, allowing them to select more than one role. This references a custom table I created to store the values of the roles.
If the customer changes the question from Yes to No
The List collector does not clear the selected entries.
The script I am using is not working and I wondered if someone can give me some assistance?
Steps to Reproduce
  1. Selected Related list > Catalog Client Scrips from the Catalog item form
  2. Selected onChange
  3. Selected Field sap_access_to_coe_ams { this is the Yes/No question}
var sapAccessToCoe = g_form.getValue('sap_access_to_coe_ams');   //Create variable and get the current value
if (sapAccessToCoe == 'No '); {   //if If no has been selected for Sap access to Coe
g_form.setValue('sap_role_coe');   //This is the List collector field. To set Value to null
When I save this and then try the form the values are still showing and not clearing as I would expect it to.
SMuir
Giga Guru
ServiceNow support have got back to me with a working script. If anyone is trying to do the same thing. this might help.
var sapAccessToCoe = g_form.getValue('sap_access_to_coe_ams');   //Create a variable for the Yes No field
if (sapAccessToCoe == 'no'); {   //If the yest No question for COE AMS is No
var listCollectorName = 'sap_role_coe'; //Name of your list collector
var leftBucket = gel(listCollectorName + '_select_0');
var rightBucket = gel(listCollectorName + '_select_1');
var selectedOptions = rightBucket.options;
var selectedIDs = [];
for(var i = 0; i < selectedOptions.length; i++){
//Check for the item to add here based on sys_id
selectedIDs.push(i);
//var value = selectedOptions[i].value;
//rightBucket.remove(value);
// var lefBucket = gel(listCollectorName + '_select_0');
//leftBucket.add(value);
moveSelectedOptions(selectedIDs,rightBucket,leftBucket,'--None--');
sortSelect(leftBucket);
var leftOptions = leftBucket.options;
for(var j = 0; j<leftOptions.length; j++){
var value = leftOptions[j].innerHTML;
if(value == '--None--'){
leftBucket.remove(j);
SMuir
Giga Guru
