Where can I find 'com.glide.email.max_body_bytes' in System Properties?
CharlesR1
Hello All,
We are having some problems with our inbound email actions - some of the emails received are going to junk because they are too large - example error states:
"Email set to received-ignored because its size exceeds the value set in com.glide.email.max_body_bytes.   539 character(s) were truncated from the body field."
Does anyone know where I can find (or why I can't find)   the 'com.glide.email.max_body_bytes' entry in sys_properties.list?
Charles
Midhun1
Giga Guru
You have to add the property, by default the instance wont provide it.
Email Size Limits - ServiceNow Wiki
Thanks Midhun - yes this works once created and values are increased. I don't understand how the system is referencing a system property that doesn't exist, but there you go..!
After adding this property "com.glide.email.max_body_bytes" and   set the type as Integer and the value as 31457280 . This property does not exist in our system . so i added it .
Also increased the size of this property "glide.email.inbound.max_total_attachment_size_bytes" from default = 18874368   (18MB) to the value of 31457280.
After doing this when i attach the attachment of 19.9MB it is giving error in my outlook :
This message wasn't delivered to anyone because it's too large. The limit is 25 MB. This message is 27 MB.
mta01.iad0.service-now.com gave this error:
SMTPSEND.OverAdvertisedSize; message size exceeds fixed maximum size
This message is larger than the size limit for messages. Please make it smaller and try sending it again.
Diagnostic information for administrators:
Generating server: MX20.dmz.genworth.net
gmicustsvc@service-now.com
mta01.iad0.service-now.com #550 5.3.4 SMTPSEND.OverAdvertisedSize; message size exceeds fixed maximum size ##rfc822;gmicustsvc@service-now.com
Original message headers:
we know it should be less than 25MB . Not sure how can i know what needs to be added ?
Please help me on this .
