Why is max_length not working?
08-10-2025 12:49 AM
I have created max_length attibute to Description 5 on incident table, but it is not working. I don't want to use scripting, but why is it not working. Kindly help.
Suman P.
08-13-2025 03:15 AM
Hi @ServiceNow Use6 ,
If my answer helped you, please mark it- solution accepted.
Nikhil Bajaj
08-13-2025 03:45 AM - edited 08-13-2025 04:07 AM
Hello @ServiceNow Use6 ,
Your requirement of making description field only 5 looks fishy to me , as it violates OOB behaviour of task table.
Rather i would suggest you to create new field like incident_description with default string length of 40 and then go to the backend at the dictionary side and then adjust the length, it would then allow you to enter only 4 or 5 characters based on your setting. Attached screenshots for your reference
I hope this helps, in this way you wont alter the OOB behaviour of task table , as well achieve your requirement.
