Write ATF test for Script Include
escanor
Giga Contributor
I'm trying to write a run server script test for my script include below
var EmailValid = Class.create();
EmailValid.prototype = Object.extendsObject(global.AbstractAjaxProcessor, {
	isEmailValid: function(email){
			var getEmail = this.getParameter('sysparm_id') || email;
			var regex = /^(?=.*[a-z])(?=.*[A-Z])(?=.*\d)(?=.*[$@$!%*?&])[A-Za-z\d$@$!%*?&]{8,}/;
			return regex.test(getEmail);
    type: 'EmailValid'
Pls help me !
Ankush Agrawal
Hi
Please follow the below steps:
  1. Go to Automated Test --> Test
  2. Create a Test
  3. Add a step to 'Run Server Side Script'
  4. Write the following lines
var emailToTest = 'test@amIValid.com';
var emailValid = new EmailValid();
return emailValid.isEmailValid(emailToTest);
You can use any one of the strategies as per your preference:
  1. Create an array having different emails. Set a boolean flag 'result' to true. Iterate over each element and set the boolean to false if any of the verification fails. Return this boolean flag outside the iteration.
    1. Pros: Clean code
    2. Cons: Test result count will show only 1 test is executed. Not a clear report.
  2. Create multiple tests to assert different email. The report will clearly say which tests passed and which failed.
    1. Pros: Clean report
    2. Cons: Duplication of code
  3. Use Jasmine to validate multiple emails.
    1. Pros: Clean report as test count will cover all the test emails. No code redundancy.
    2. Cons: Need knowledge of Jamsine.
Please let me know if you need any further information.
Best regards
Ankush
P.S.: Please mark helpful/correct as appropriate to help others in identifying correct solution.
11 REPLIES 11
The function in the script includes EmailValid returns false for those emails. I will suggest checking the regular expression there.
ty bro finally i got it
