Difference between WorkFlow and Flow Designer
ma kaiyue
Giga Guru
Can all functions of workflow be implemented using Flow Designer? Can Flow Designer completely replace Workflow?Are there any differences between them in terms of what can be achieved?
Thans in advance!
Aman Kumar S
Hi @ma kaiyue
Most of the features that you have in workflow, you will have the same features in flow.
Although certain features as rollback is missing in Flows but that can be compensated by having additional logics and subflow.
Flow is the new way of working, which makes configuration much easier and smoother.
Go through below SN articles to understand more:
https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0789014
Best Regards
Aman Kumar
Harish KM
HI @ma kaiyue  Not all 100%, there is no roll back action in flow designer yet, but flow is more matured now compare to earlier versions, It depends on your requirment, I would say start with flow designer for all new catalog items and slowly replace for existing ones
Harish
Aman Kumar S
Hi @ma kaiyue
Best Regards
Aman Kumar
