Employee center Topic Header widget issue
Mbrk
Hello Everyone,
After changing the theme of employee center and reverting back to the OOB theme i am getting issue with one of the topic created mentioning topic header (Failing widget: 'Topic Header' (10e99777c38830105a09f0ad9840ddbd)) && Failing widget: 'Content Experience' (26b2b8cfff02201014c6a36cf43bf1a0).
Although for other topic it is not showing the issue. And also there is no change in the code for the widgets as those widgets are OOB.
Can you please help in resolving the issue.
And is there already one for the Content Experience record? If not, create a new Restricted Caller Access record.
Kind regards,
Mark
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
Look for "Requested" status as well. For me, it was "Requested" at first before I modified the code in the widget. I changed it to "Allowed" and tested it. It worked fine, but as soon as I modified the widget code, I started getting the same errors again, so I went back and found that the status changed to "Invalidated". I "Allowed" one more time and it worked fine again.
