12-16-2024 06:57 AM
Is it possible to hide Author name in knowledge article in employee center portal without customization. I have checked instance options, there is no option available in employee center portal to hide author name.
12-17-2024 11:04 AM
Well, it looks like that CSS may be old and is not needed anymore. I was working in my PDI and found that if you update the following instance options you can hide the author by simply not including it in the secondary fields. Looks like if you don't select anything then the default fields show up.
12-17-2024 11:04 AM
