Automated Responses on Smart Assessment do not correctly populate an answer
Tamara Sylte
I'm trying to meet a requirement to automatically answer some questions in a GRC Smart Attestation for a Control.
Use case 1:
I have a radio button question with 2 answers (Yes/No) (Question 1). Then I created another radio button question with the same options (Question 2). If Question 1 is answered Yes, then Question 2 should default to Yes. Or if Question 1 is answered No, then Question 2 should default to No. However, when attestations are generated and completed, Question 2 is always  set to No. [Note the same behavior is observed for Drop-down and Check-box questions.]
Use case 2:
A question must be answered based on a value from the Entity's underlying record. I am attempting this with a script, however nothing that I can think of to try will get the answer to populate. I can run the script independently and it fetches the value I need, but when I try to answer the radio button question using the values shown on the form, nothing happens. No error is thrown, and gs.log/gs.info don't print anything. I even tried just setting the value (not using the GlideRecord lookup etc.)
Has anyone succeeded in getting the Automated Responses feature to work?
2 ACCEPTED SOLUTIONS
Pooja Kotagiri
Use case1:
Under Additional Options, there is a setting called 'Set response as editable'. When this is enabled (set to true),Response automation settings are evaluated only when the assessment is triggered. If it is disabled (set to false), the Response automation conditions are re-evaluated every time a dependent question changes. This behavior was not documented previously, but we will update our documentation to include this.
Pooja Kotagiri
Use case2:
To set a radio button using a script, assign the value using: result.value = <response option sys_id>
11 REPLIES 11
Vinod54
Hi @ColeM , @NitheeshkuS @Pooja Kotagiri , @Tamara Sylte ,
Please find my article on
What are the automation or scripting options available in Smart Assessment Engine?
That will help you to implement automation and complex configurations in Smart Assessment Engine.
Vinod Kumar M
If my reply help you, please select it as Helpful.
Please see the screenshots I provided, I believe my configurations are aligned with your article but it is not working for the FSM agent mobile app.  Have you had success with automating responses for mobile?
