10-11-2024 05:31 AM
How metric data task flow works?
Linear stages New->In progress->Awaiting approval->closed
To whom approval is send? what could be the reason of not sending the approval?
@Community Alums
10-12-2024 02:38 AM
Hi @Tejas9
In ServiceNow, a metric data task flow helps track task statuses over time (like a linear progression through statuses). For your flow:
Stages in Metric Data Task Flow
New:
- A task or request is created and awaits processing.
In Progress:
- Work is actively being done on the task.
Awaiting Approval:
- The task requires approval to move forward (e.g., from a manager or stakeholder).
Closed:
- The task has been completed or resolved.
10-11-2024 10:30 PM
Hi @Tejas9 ,
Can you please attach some sceenshots of your issue. Also , provide more context on what metric data you are referring , where it is being used?
10-12-2024 05:43 AM
I missed to select approver in metric definition form So the stage was not going to Awaiting approval stage.
10-12-2024 02:38 AM
Hi @Tejas9
New:
In Progress:
Awaiting Approval:
Closed:
10-12-2024 05:38 AM
Thanks Prashant 😊
