How to set default values for assessor when assessing risk in Risk Workspace ?
rd063
While doing a Advanced Risk Assessment for a Risk in Risk Workspace , how can I set the default values for "Assessor Type" and "Assessor Group " . Please find the screenshot below :
Please if someone could help me here that would be great .
11 REPLIES 11
Hi @Joe Macleod ,
The assessor, approver fields are hidden based on the state variable. These variables are set using client scripts which can be assessed on the UIB page through the icons present in bottom left section.
There are 2 scripts which update the hidden property:
  1. Handle events
  2. onLoad
Please review these scripts and then customize based on your requirements.
Jai
Please mark this as helpful if it solves your query.
Jai
ShafrazMubarak
Giga Guru
You can set the default assessor using following methods.
1. Go to Risk Assessment Scope --> Create
2. Select the Assessment methodology and the assessable entity.
3. In the settings tab, select the assesor type, approver and frequency.
