Indicator Task not running
Alfredo6
Hi! I have several questions hoping you guys can help..
We have activated the GRC module to automatically generate tasks based on indicators that trigger the compliance status in the Control.
However I have identified that the Indicator Task will run but will not update the "Next Run" Time if it doesn't has a value in the "Table" field from the "Collect Supporting Data", even though that checkbox is false. Is this how it is supposed to be or is it a problem?
Also, is there a way to update the OOB script? I've seen that Indicator Task won't run if the Control is Non-Compliant, and we require to keep asking for Deliverables on a regular basis, we use the Indicator Tasks for the user to submit these Deliverables, but if an Issue is still open, then the Task will not be created.
Thanks!
vinothkumar
It is a known error and it was fixed in Helsinki Patch 9.
Helsinki Patch 9
Alfredo6
Thanks everybody for your responses!
Cheers!!
