IRM Advanced Risk max, min, avg nad sum_calculated_ale
Jerold Servi_o
Giga Contributor
Does anyone know how these four fields for sn_grc_profile table are being filled? max_calculated_ale, min_calculated_ale, avg_calculated_ale and sum_calculated_ale. I found a script include that seems to do it but upon further analyzation and following the flow it ends up with a function that isn't getting called anywhere. Any help with this is greatly appreciated. Thank you.
11 REPLIES 11
Did you get the answer how those value be populate in ServiceNow and tolerance status calculated
Hi @ShalluM
These fields are updated by Advance risk Application
There are two scenario in ARA after we install the application
1. We didn't activate ARA from system property which will activate RAM functionality
2. We activate RAM by enabling the property
The fields they are referring will be updated in 1 scenario as score roll up will be done because of ARA application but still be using old assessment as RAM is not enabled due to the property.
