Populate recipients First name in the email body for a particular group
taylor13
I am trying to send an email notification to a group of users. I have a salutation in the Body of the email saying Hello "Name". How do I populate the recipients name in "Name" such that each user who receives the email gets their own name in the email salutation?
@Ankur Bawiskar @Community Alums @Aman Kumar S
Ramu Neelam
Giga Expert
Hi Taylor,
If the notification recipient is a group, then system generates only one single email and content will not be generated dynamically for each individual recipient.  However, if you are ok to have all the recipients separated by comma or slash then you can achieve this using email script:
Write an email script and get the recipient name(s) from the group and then generate a concatenate string will all the recipients separated by "/". For example, the notification group is Business_Users_Group which contains two users in it (Ramu Neelam and Taylor Joy). The email script iterates the group members and generates a string "Hello Ramu / Taylor".
Please keep in mind that ServiceNow generates single email and send it to all the group members but not multiple individual emails (separate email for each recipient). So, you can't generate email body like "Hello Ramu" for Ramu's email and "Hello Taylor" for tailor email because it is only one email where both Ramu and Taylor is copied.
Please let me know if you need any help with the email script.
Ramu Neelam
11 REPLIES 11
Hello Sandeep,
Check below links in the email body its showing only group name but i want individual recipients name:-
https://INSTANCE-NAME.service-now.com/now/nav/ui/classic/params/target/sysevent_email_action.do%3Fsy...
Hi @taylor13 ,
 It shows group name because, in "Who will receive" section, you have a group name mentioned.
And you have "${assessor_group} on your email body, what you can try is below:
and:
Abhishek_Chavan
If you are using flow to generate the email, you can use the data pill to refer to the user.
However, if you are using the notification form. you can use the fields under 'who will receive' to mark the sender.
And use the variables field under 'What it will contain' section to address the user something like '${opened_by.first_name}'
Let me know if you have any questions.
Hello ,
Thanks for your quick reply!
Actually we are providing assessment approval notification in Risk Assessment Module. as per OOTB functionality its taking only Entity Owner name. we want to send notification to Particular Group assume XYZ is a Group and we both are part of that Group. so, whenever i received the email I want message as a Hello Taylor joy, for you it will be Aman Kumar.
Actually I have Tried the email script trying to call out in the notifications but it's not working
Hi @taylor13 ,
While configuring your notification, under the "What it will contain" section, if you scroll down, you can find a "Fields" , just hit the "+" icon and add the fields(which is the first name for you) into your message/email body:
