Difference between HAM and Ham Pro
sidharthaa
what is the Difference between HAM and Ham Pro in ServiceNow.
what is the advantage of implementing HAM Pro ....
glideFather
Hi @sidharthaa,
you can watch this video at the official SN channel: The Difference between Core Asset Management & Hardware Asset Management
If I remember correctly, it was explained there
SAMfluencer
Hi @sidharthaa ,
Check this link it gives you a detailed overview : https://www.servicenow.com/community/ham-blog/core-asset-management-vs-ham-pro-what-you-actually-get...
The article also has a PDF attached at the bottom covers the full feature matrix, lifecycle stage coverage, and decision guide. Worth downloading and keeping as a reference.
If this helped - amazing, you're welcome, go click Helpful and Accept as Solution. If it didn't - well, at least you learned what not to do. Either way, we grow.
Cheers, Abby
ITAM Principal Solution Architect
fknell
Hi @sidharthaa,
on the one pager below you will find the differences between both solutions.
Each feature you can explore here: Exploring Hardware Asset Management
Hope this helps!
