05-15-2024 03:36 PM
Has anyone completed the Lab 03.01 - Create Voluntary Separation Lifecycle Event, please so can you share how can I commit update sets for Voluntary Separation with 'State' as- Previewed (In Batch) as I cant find 'Committed State' with Parent- 'P-Separations'. I am using Global scope.
Kindly suggest. Thanks in advance.
05-19-2024 03:59 PM
As I said previously and as the lab instructs, you need to resolve the errors by selecting the Accept Remote Update link in the Available Actions column.
05-15-2024 08:09 PM
05-16-2024 03:15 PM
Hi James,
Thanks for your revert. Below are the screenshots of the lab instructions.
Now, committed state has P-Seperations as Parent instead 'state'- Previewed (In Batch) has this parent.(sharing screenshot)
and if I try to pick any parent with P-Seperations to update, I get the below error. Plz guide.
05-16-2024 03:30 PM
Can you try selecting Run Preview Again for batch and share the errors in the related list?
Normally it shouldn't throw errors in a lab instance but it could happen.
05-16-2024 04:52 PM
Hi James,
Thanks, I tried to select 'Run Preview again for batch' but still getting the same error.
Also as shared in the lab, the 'State' should be 'committed' with P-SeparationsExPack v2.6 as Parent but if I filter with committed state, there is no parent with P-Separation data..
Can you guide. Thanks
