Current.update() after insert business rule
Rushi2
I have field A (currency type). While creating a record I give some value it has to copy on field B(current field).
After insert
current.b = current.A;
current.update();
is there any option without using current.update();
Rushi
Rocking_RJ
Hi Rushi,
Current.update() is not recommended in an After insert business rule, so If you want to update any field then use Glide Record script to update the field value.
As you want the first value of field A to B then try to create your BR with Before insert , if value of field A is available at the time of record creation.
