Flow designer issue lookup records
anwar basha2
Hi Everyone,
I have lookup records action in my flow using that I want delete multiple records   but the out put of lookup records action records is truncated due to the long sys_id's. As per existing solution from service now allows only  466 records .But in my case I have more records is there any way how we can achieve this.
Please give the solution flow designer experts.
Thanks!
Tai Vu
Hi @anwar basha2
Have you tried with a custom flow action with a script step using deleteMultiple() ?
Cheers,
Tai Vu
Hi @Tai Vu,
Thank you for reply!
No I did not try yet let me try.
