GlideModal help
Naga Ravindra R
Hi there,
we have a ui action with following script:
function par_req() {
    var gm = new GlideModal("glide_prompt", true, 1600);
    gm.setTitle("Create Product Allocation Requests");
    gm.setPreference("title", "Number of Allocations Required (Max 50)");
    gm.setPreference("onPromptComplete", function(value) {
        g_form.setValue('number_of_product_request', value);
        g_form.save();
        gsftSubmit(null, g_form.getFormElement(), 'add_product_allocation_requests');
    gm.render();
when user clicks on it, it will show like below:
Ideally we are setting the value in a field, That field is of type integer. But If user enters alphabets, we have to show error.
For ex, if user enters 4a, I have to show error saying the please enter only number. Also if user tries to submit, do not let them submit it.
Is there any way I can perform the validation in UI action? Any references.
Please let me know. Thank you
Sohithanjan G
Hi @Naga Ravindra R ,
Can you try this
        if (!isNaN(value)) {
            var intValue = parseInt(value, 10);
            if (intValue >= 1 && intValue <= 50) {
                g_form.setValue('number_of_product_request', intValue);
                g_form.save();
                alert("Please enter a number between 1 and 50.");
            alert("Please enter only numeric values.");
    gm.render();
Please mark as Accepted as Solution !!!
Naga Ravindra R
Guys, I did something like this and it's working fine.
        if (isNaN(value)) {
			alert("Please enter number only");
			gm.destroy();
            g_form.save();
    gm.render();
Thank you so much @Sohithanjan G.
