How to track assigned to changes and who changed it
Shusovit Dutta
I want to track the assigned to changes and who changed it on a dashboard to agents via a dashboard. How can it be achieved.
Hi @Shusovit Dutta
It seems my previous reply was missed.
Using metrics is one way to approach this. However, there’s no direct field to track who changed the "Assigned To" value, as anyone can update it. That action is only captured under the Updated By field.
Since any field change on the incident updates the Updated By, it doesn't specifically tell you if "Assigned To" was changed. So, there’s no direct out-of-the-box (OOTB) way to track who made the assignment change.
The best you can do with standard metrics is to track who the ticket was assigned to previously and who it is assigned to now.
Ankur Bawiskar
@Shusovit Dutta
there is OOTB metric on assigned_to field which tells the INC was with which Assigned to user for what duration
you can report on that
see this link on how it can be done for assignment group and repeat same for assigned to field
How to Create a Historical Report Based on Assignment Group Changes on the Incident Table
I want to track who changed it as well. If i create another definition will not look good. Can it be done via something else like PA?
@Shusovit Dutta
then do this -> I won't recommend reporting on system table but if you still want then
  • Create a report on the sys_audit table.
  • Filter for records where Field name is "assigned_to" and Table is, for example, "Incident" or your relevant table.
  • Show columns including: Record, Old Value, New Value (Assigned To), Updated By (Who changed it), and Updated On (When).
  • For a dashboard, add this report to a Platform Analytics or standard dashboard as a list or chart widget.
OR
Another approach is to use custom field to track
Tejas Adhalrao
Hi  @Shusovit Dutta ,
sys_audit already tracks all changes including assigned_to .. a You can directly use it to create a Report / Dashboard..
1)
TejasSN_LogicX_1-1759838514553.png click enter
2)aaply filtera nd you can tract the changes
 thanks,
tejas
would be difficult to put it in a report and show it to agents
