Incident creation ig group does not have members or owners
Kaustubh k
Hi Team,
We have below requirement,
If any of the group does not have any members or owners or managers then an incident should be created and assigned to a Admins group.
multiple incidents should not be created for same set of groups.
How can we achieve this.
thanks
Hello @Kaustubh k
Sorry for inconvenience caused to you. I have modified script include code and tested this time in my PDI 😉
var CheckEmptyGroups = Class.create();
CheckEmptyGroups.prototype = {
    initialize: function() {},
 checkGroups: function() {
        var gr = new GlideRecord('sys_user_group');
        gr.addActiveQuery();
        var emptyGroups = new Set();
        while (gr.next()) {
            var groupId = gr.sys_id;
            var groupName = gr.name.toString();
            // Check if the group has members
            var memberCount = new GlideAggregate('sys_user_grmember');
            memberCount.addQuery('group', groupId);
            memberCount.addAggregate('COUNT');
            memberCount.query();
            memberCount.next();
            var hasMembers = memberCount.getAggregate('COUNT') > 0;
            // Check if the group has owners or managers
            var hasManager = gr.manager.toString() !== '';
            if (!hasMembers && !hasManager) {
                emptyGroups.add(groupName);
        if (emptyGroups.size > 0) {
            this.createIncident(Array.from(emptyGroups));
    createIncident: function(groupNames) {
        // Check if an incident already exists for these groups
        var existingIncident = new GlideRecord('incident');
        existingIncident.addQuery('short_description', 'Groups with no members & managers');
        existingIncident.query();
        if (existingIncident.next()) {
            return; // Incident already exists
        // Create a new incident
        inc.initialize();
        inc.short_description = 'Groups with no members & managers';
        inc.description = 'The following groups have no members or managers:\n' + groupNames.join('\n');
        inc.assignment_group = 'your_group_sys_id'; // Replace with the sys_id of the Admins group
        inc.insert();
    type: 'CheckEmptyGroups'
Thanks & Regards
Viraj Hudlikar.
11 REPLIES 11
Dr Atul - LNG
Hi @Kaustubh k
To create a Flow in ServiceNow that runs weekly and handles the condition you mentioned, you can use Flow Designer to automate the process. Here’s a step-by-step guide on how to build the flow:
Step-by-Step Flow Creation in ServiceNow:
1. Create the Flow in Flow Designer
2. Add a Trigger for the Flow
  • Select Scheduled Trigger as this needs to run on a weekly basis.
3. Add an Action to Lookup Records in the Group Table
  • Action Type: Use Lookup Records.
  • Choose the Group table (sys_user_group).
  • Add the following conditions:
    • Manager (field) is empty. This checks for the groups where the manager is missing.
4. Create an Incident Record for Each Group
  • Add an Action: Create Record.
  • Choose the Incident table (incident).
  • Set the following fields based on the conditions and information you have:
    • Assignment Group: Set this to the group found in the previous step (use dynamic fields to reference the group record).
    • Short Description: Set this field based on your requirement, such as "Incident created due to empty group manager".
    • Set other necessary fields (e.g., Description, Priority, etc.) as needed.
5. Activate the Flow
Viraj Hudlikar
Tera Sage
Hello @Kaustubh k
Script Include name - CheckEmptyGroups
Script as below:
        while (gr.next()) {
            var groupName = gr.name;
            memberCount.next();
            //var hasOwner = gr.owner != '';
            var hasManager = gr.manager != '';
                this.createIncident(groupName);
    createIncident: function(groupName) {
        // Check if an incident already exists for this group
        existingIncident.addQuery('short_description', 'Group ' + groupName + ' has no members & managers');
        inc.initialize();
        inc.short_description = 'Group ' + groupName + ' has no members & managers';
        inc.insert();
A scheduled job name "Check Empty Groups" as per your requirement set Run and in script we can our script include which will create incident and if already existing incident we skip that group as per logic set in script include.
var checker = new CheckEmptyGroups();
checker.checkGroups();
Thanks & Regards
Viraj Hudlikar.
Hi @Viraj Hudlikar ,
Thanks for your response and its working.But if I have 80 groups ,it is creating 80 Incidents.
Could you help me to achieve the following thing:
It should create only 1 incident with all the  80 group details.
Thanks in Advance
Hello @Kaustubh k
Since your use-case has changed so the modified code will be as below:
        var emptyGroups = [];
        while (gr.next()) {
            memberCount.next();
                emptyGroups.push(groupName);
        if (emptyGroups.length > 0) {
            this.createIncident(emptyGroups);
        inc.initialize();
        inc.short_description = 'Groups with no members & managers: ' + groupNames.join(', ');
        inc.insert();
Calling of script include will be same as shared previously.
Thanks & Regards
Viraj Hudlikar.
Thanks for the response
I missed this yesterday, today when I was checking found that,it involves the same group name
Output: Groups with no members & managers: O2C_GBO_Inter-IntraCompany Billing_UK, O2C_GBO_Inter-IntraCompany Billing_UK, O2C_GBO_Inter-IntraCompany Billing_UK,
And also I need the output ,each group in separate lines,so it is easy to understand.
