Need solution for autonumbering in incident records
keerthika98
Each time when i open new incident form, a new incident number is generated.
If i don't submit and reopen it, another number will be generated.
If would like to prevent this behavior by implementing a custom business rule. Need sample code for this requirement.
Anirudh Pathak
Hi @keerthika98 ,
Change the system property "glide.itil.assign.number.on.insert" to true.
Reference - https://docs.servicenow.com/bundle/washingtondc-platform-administration/page/administer/field-admini...
Shivambitanwar1
Hi @keerthika98 ,
If you set glide.itil.assign.number.on.insert property to true , it will Assign a task number only upon insert (prevents unused numbers). You will not need a BR,
Warm Regards,
Shivambi
Harish Bainsla
Hi
  1. Navigate to All > System Properties > System.
  2. Set the property Assign a task number only upon insert (prevents unused numbers), glide.itil.assign.number.on.insert
Priyanka_786
@keerthika98 :
 I believe your ask in only for incident table. If yes , please be thoughtful that if you use Property option as suggested by all other fellows as it will be applied on task level. (task table- which will apply to all inherited tables from task  not just incident).
So I would suggest go with Business Rule in this case. For logic, have a look into this thread-https://www.servicenow.com/community/developer-forum/auto-assign-incident-number-onsubmit-instead-of...
 Note:- In this thread Client script approach used ,but you can refer the same logic for Business Rule.
Hope it helps. Please mark helpful/accepted if it helps.
Priyanka Salunke
