State of problem form changes to close on form even though script prevent state from changing state
‎01-23-2024 04:29 AM
I have a script that prvents a problem from changing from the state resolved to closed when there is no related problem task or change. The script works fine, but the state on the form changes to closed until I reload the form and the state goes back resolved. Is thereany solution to this problem, as I don´t really want to tell my client that he needs to reload the form to actually see that the script is working and prevents the problem to change it´s state to closed.
‎01-24-2024 01:53 AM
HI @jthomsen
I am not coder 😞 , but would like to know what type of BR It is, before or after?
Adding @Jaspal Singh for inputs.
‎01-24-2024 02:01 AM
Hi @Dr Atul G- LNG No Problem :). The BR is a before update BR
‎01-24-2024 02:03 AM
Let's wait to hear from @Anurag Tripathi / @Jaspal Singh
‎01-24-2024 02:15 AM
@jthomsen travianwrote:I have a script that prvents a problem from changing from the state resolved to closed when there is no related problem task or change. The script works fine, but the state on the form changes to closed until I reload the form and the state goes back resolved. Is thereany solution to this problem, as I don´t really want to tell my client that he needs to reload the form to actually see that the script is working and prevents the problem to change it´s state to closed.
You can use the onchange event for the form's status field. This event will fire whenever the value of the status field changes.
‎01-24-2024 02:17 AM
@jthomsen travian wrote:I have a script that prvents a problem from changing from the state resolved to closed when there is no related problem task or change. The script works fine, but the state on the form changes to closed until I reload the form and the state goes back resolved. Is thereany solution to this problem, as I don´t really want to tell my client that he needs to reload the form to actually see that the script is working and prevents the problem to change it´s state to closed.
