How to edit SOW home page workspace
SS1510
I have to edit the homepage of Service operation workspace--
1. On the SOW home page add a new tab after Your Work and Your team's Work, named Unassigned work and under that we have to create a new widget
2.On the Your Work tab:
  • Add a new widget for Project tasks assigned to you
3.On the Your team's work:
  • Project tasks assigned to your team
4.Can we add quick links to appear across a specific role?
Does anyone has any idea how to configure these ?
Ankur Bawiskar
@SS1510
it's a platform analytics dashboard rendered on SOW Landing page
You can add New tab or add new data visualization in existing tabs in that and it will reflect in SOW landing page
Steps: Ensure you are in correct scope "Service Operations Workspace ITSM Common"
1) open this URL for that platform analytics dashboard "Overview"
https://instanceName.service-now.com/now/platform-analytics-workspace/dashboards/params/edit/false/t...
2) then click the Edit and Add New Tab using + icon and add Data Visualization you want and click Save
Output: New tab and data visualization seen on SOW Landing page
For quick links check this article
Service Operations Workspace – How to add “Global” quick links?
11 REPLIES 11
@SS1510
are you in correct scope and are you admin?
I was able to save as admin and it worked for me.
I believe I shared a working solution.
check below links for that error
Dashboard is not saving changes after editing & throwing an error "Your dashboard could not be saved...
Platform Analytics Dashboard - Not saving
SS1510
@Ankur Bawiskar
Yes, i am in Service Operations Workspace ITSM Common scope and admin
@SS1510
clear instance cache using cache.do and then logout and login again
also check the 2nd link I shared above.
@Ankur Bawiskar ,
I have a confusion ,
There are two overview visible in platform analytics - dashboard, which one to choose
@SS1510
You can compare visually in your SOW which one is present here and then modify that
Also check below point
there are 2 dashboards and each one is added to respective landing pages 1 for Tier 1 and other for Tier 2
Tier 2
https://instanceName.service-now.com/now/sow-admin/donut-configuration/2
Tier 1
https://instanceName.service-now.com/now/sow-admin/donut-configuration/1
