Searching reference fields in workspaces
mrosok
I'm trying to figure out how automatic searches on fields are configured. When I create a case in CSM/FSM workspace and select the Account field, before I write anything a list of search results are displayed under the field. This search is updated as you type.
When I create a change request in SOW and select the Company field, if I don't write anything I get the same search underneath, but it says "No results found". If I start writing something I will get relevant search results, so there is nothing wrong with the reference qualifier.
If I open up a case in the core UI, I will not get any search results on the field unless I start writing something. I'm assuming this instant search is something that is tied to workspace functionality?
I would like to know how/where this is configured. Preferably I would like both workspaces to behave the same way when it comes to searching fields.
mrosok
Found an answer to this in the release notes for SOW Yokohama:
Reference field behavior changes in SOW
Selecting any reference field in SOW now displays only the recent selection values instead of automatic searching and displaying the results of the field values available in the system. This change increases the overall performance of the reference fields. By default, this change is enabled. To revert this change, set the Reference search on click (ref_search_on_click) UX page property to set to true
https://www.servicenow.com/docs/bundle/yokohama-release-notes/page/release-notes/it-service-manageme...
ysrivast
anyone can help how to do the step "To revert this change, set the Reference search on click (ref_search_on_click) UX page property to set to true"
