Instance under maintenance for past few days and not able to access it.
servdevyounus
Developer Instance is undergoing unscheduled maintenance. Get Notified when your PDI is available. I am seeing this message from past few days and my instance is offline .please help me with this issue.
Dr Atul G- LNG
Hi @servdevyounus
There are high chances it will take more time or you will not get this back. If your work is urgent take a new instance.
If my response proves useful, please indicate its helpfulness by selecting " Accept as Solution" and " Helpful." This action benefits both the community and me.
Topmate: https://topmate.io/atul_grover_lng [ Connect for 1-1 Session]
AndersBGS
Hi @servdevyounus ,
As you might know, there is no support available from ServiceNow in relation to PDIs, hence you're limited to two options.
  1. Wait - It should come online after some time.
  2. Release your instance and request a fresh installation.
Based on the information that you have provided, I would go with option 1 for some more time, especially if you have some development work that you haven't backed up.
best regards
Anders
Best regards
Anders
Rising star 2024
MVP 2025
