Predictive intelligence on client side not populating prediction results table?
Liyakhat
Hi
I tried to run Predictions on client side and was successfull following below article
https://www.servicenow.com/community/ai-intelligence-articles/in-predictive-intelligence-how-to-get-...
But i observed its not populating prediction results table to view in reports
Any possible way to populate the table prediction results using client side predictions
@Pradyumna Das @Brian Bakker
Brian Bakker
@Liyakhat
You should use the applyPrediction method to populate the Prediction Results table. Here is an example -
var mlSolution = sn_ml.MLSolutionFactory.getSolution("ml_incident_categorization");
var inputGR = new GlideRecord("incident");
inputGR.get("0ef47232db801300864adfea5e961912");
mlSolution.applyPrediction(inputGR);
Brian
Brian Bakker
@Liyakhat
You can also use the SolutionStats API to record the predicted values into the ml_predictor_results table.
/ This below line of code will set the predictions in ML Predictor table
sn_ml.SolutionStats.recordPredictValues(results, solution);
