Aruba Wired/Wireless Integration
Alex Ward
Mega Guru
I've been asked the question about the feasibility of an integration between ServiceNow and Aruba.
In its simplest terms does anyone know if Aruba can be integrated with ServiceNow.
I have asked the question of, "what would you like the integration to do?", but have not been given any indication...... So it is unclear how the customer would like this integration to work, in terms of a Push of data from ServiceNow, or a Pull/Push from Aruba.
I've searched the internet for mention of an Aruba integration with ServiceNow but don't seem to be turning much up. There is mention of ServiceNow in the Aruba community, but having no knowledge of Aruba, I don't know if this is in the right context.
Any thoughts or experience peeps?
monica12
Mega Contributor
Tried, but while testing in the pattern its coming as:
I probably do things the hard way but i will run a quick discovery on one of the IP's of the controller and make sure on the shazam input payload that i see the following:
<scanner name="SNMP" port="161" portprobe="snmp" protocol="udp" result="open" service="snmp">
<snmp_version>3</snmp_version>
</scanner>
This tells me that it is configured to send information through snmp.
holly-t
i would check this out for discovery help but not orchestration.
Aruba relationships
