Does ServiceMapping shows connection between VM & Corresponding ESXi server
Chaitanya86
Does ServiceMapping shows connection between VM & Corresponding ESXi server?
for ESX in service mapping are u using ESX URL as a triggers point.
Service Mapping -Maps your application and Its Running Components...So ESX URL running on which servers /DBs /Web Servers etc. VM are internally managed Objects by Vcenter ESXi.
a given ESX may have >100 VM on it correct.
In Service Mapping lets say ur Mapping  for ESX setup these VMs are not playing any role Impact wise. At this point of time i can only say it may need a deep customization.
RP
Hi @Rahul Priyadars
I am Discovering it through vCenter.  I am asking mapping reverse way.
Like in Service Map, i have Web , App & DB Servers & need to show in map that servers are depended/Configure on which ESXi box.
I got what you are saying -
In your environment you ran Vcenter Discovery, IP based Horizontal Discovery.
Currently do u have relationships/connection between ESX n VMs (Win Server Virtualizes :: Virtualized By  ESX) ????
Now when u run the Top down service mapping you are looking for Connection Between A server/Host of the MAP  and Underlying ESX host.
RP
Hi @Rahul Priyadars,
 Currently do u have relationships/connection between ESX n VMs (Win Server Virtualizes :: Virtualized By  ESX) ???? - Yes its showing relationship between VM & ESX.
Now when u run the Top down service mapping you are looking for Connection Between A server/Host of the MAP  and Underlying ESX host.  - Yes thats correct.
I have not started any service mapping yet.
Hi @Rahul Priyadars
Have created one service map. But its not showing connection between VM & ESXi.
But if i open dependency map it shows relationship.
In that case run the Service Mapping Top Down Discovery and Update here..
