Firing a notification using a background script.
Emily7
Kilo Explorer
Hi SN developers!
I am trying to fire a notification when a priority 1 incident occurs. Here is the screen shots.
It works correctly when I create a new priority 1 incident or update the incident priority using "Update" button.
However, when I create a backgroud script and update the priority to 1 but the notification doesn't fire. Is there any advice? Thank you in advance.
Phuong Nguyen
Hi Emily,
In your background script, you have gr.setWorkflow(false); this prevents business rules and workflows from running, hence your business rule does not fire the event.
Phuong
If you find my suggestions helpful, please mark it as correct or helpful to help out others as well 🙂
Ankur Bawiskar
since your script has setWorkflow(false) it is stopping email from being sent;
can you try to remove that and check once
Mark Correct if this solves your issue and also mark Helpful if you find my response worthy based on the impact.
