11-20-2014 05:45 AM
For change management module we are using OOTB UI macro 'approval_summarizer_default' for showing fields in My approvals.
Now I want to add some more fields to that My approvals for that where I have to change in UI macro?
Below is the OOTB code for that
<j:jelly trim="true" xmlns:j="jelly:core" xmlns:g="glide" xmlns:j2="null" xmlns:g2="null">
<g:evaluate var="jvar_has_source" >
var flag = !${ref}.sysapproval.nil() || !${ref}.source_table.nil();
flag;
</g:evaluate>
<j:if test="${jvar_has_source}">
<g:evaluate var="jvar_ni" expression="
var gr = null;
if ( !${ref}.source_table.nil()) {
gr = new GlideRecord(${ref}.source_table);
gr.get( ${ref}.document_id);
gr = new GlideRecord('task');
gr.get(${ref}.sysapproval);
<g:evaluate>
g_approval_form_request = true; // this global is checked in ACLs
</g:evaluate>
<g:evaluate var="jvar_my_form">
var gc = new GlideController();
var p = new GlidePopup(gc, "${gr.sys_class_name}");
p.putParameter("sys_id", "${gr.sys_id}");
p.putParameter("sysparm_view", "approval");
var rp = p.getRenderProperties();
rp.setSmallCaption(true);
var s = p.getPopup();
s;
</g:evaluate>
<tr id="approval_summary_row">
<td width="100%" colspan="2">
<j2:if test="${gs.getProperty('glide.security.use_csrf_token')}" >
<input type="HIDDEN" name="sysparm_ck" value="$[gs.getSessionToken()]"/>
</j2:if>
<div id="approval_summary" style="padding-top:8px;display:none;">
<div class="caption" style="padding:4px;">${gs.getMessage('Summary of Item being approved')}</div>
<div style="padding-left:2px;"><g:no_escape>${jvar_my_form}</g:no_escape></div>
</div>
</td>
</tr>
<g:evaluate>
delete g_approval_form_request; // removes the global
</g:evaluate>
<script>
addRenderEvent(moveSummaryForm);
function moveSummaryForm() {
var e = $("approval_summary");
var form = $("sysapproval_approver.do");
var formParent = form.parentNode;
formParent.appendChild(e);
e.show();
</script>
</j:if>
</j:jelly>
See the below screen shot
Here I want to add and remove some fields.For that where I have to change in that UI macro
Service Mapping
11-30-2014 06:44 AM
You can use an if statement in the g:evaluate block where the p.putParameter("sysparm_view", "approval"); line is. Just use the gr object to check the user selected value on the change request and pass in the view name for approval.
11-21-2014 02:31 AM
How can I write for default view to show the fields in approval view and for other view to show the fields in approval 1 view.
11-21-2014 06:36 AM
What do you mean by default view? Is there a field or something that controls which view your users are supposed to see between approval and approval1 view?
11-21-2014 07:06 AM
Actually when user selects create new from change module then we will ask for which type of change you want to create based on the option selected by the user we show the form.
Suppose if user selects option 1 then we will show the default view --- here fields and approvals are different
Suppose if user selects option 2 then we will show the view 2 ----here fields and approvals are different
Now what my point is in My approvals default view fields are showing even if approval is for view 2
So where i have to modify in that script so that for 'default view approvals' -- default view fields should be displayed and
for 'view 2 approvals' -- view 2 fields should be displayed
11-21-2014 08:43 AM
Are you understood what I am saying?
11-23-2014 11:24 PM
in simple
for default view --- in My approvals I want to show some fields
For other view ---- in My approvals I want to show some other fields
for that where I have to modify in "approval_summarizer_default" script ?
