How to send event from Kibana to Snow using ServiceNow ITOM Connector
ninhnguyen
Hi Snow team!
I am working on integrating the our Kibana to send metrics Snow using ServiceNow ITOM Connector.
However when i tried to test sending events from Kibana, it requires the Severity params, I couldn't find anyplace to set this up.
Could you gimme some advise?
Much appreciate!!!
Hi @ninhnguyen
you can try out Event Management on your PDI.
The request process for PDIs is simplified and possible after logging in at developer.servicenow.com:
Maik
13 REPLIES 13
Hi
This is how the flow is
Monitoring System--Event--->Service Now Event Record---Service Now Alert Record ---Service Now Incident
For this Flow you definitely Need Event Management Plugin Enabled on Your System.
(1) If your monitoring System is Behind the Secure N/W then you need Mid Server (Pull from ServiceNow)
(2) if your monitoring System is exposed on Internet - then U do not need Mid Server as Service Now Can reach the System using API.
Now As Maik Said - Kibana can Consume Service Now REST/Scripted Rest etc to Post event data to Service Now Event Table (em_event).
POST https://dev76115.service-now.com/api/now/table/em_event
This KB explains basics of Service Now Event Management
https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0756665
RP
ninhnguyen
Thanks again @Maik Skoddow @Rahul Priyadars
I tried to install EventManagent plugin on my Snow instance but it seems my account is just developer level and not under any company Snow license so i couldn't login snow store to request plugin and install. is that correct?
if Yes, i will find the support from higher manager to get license.
Could you gimme some advice? it is blocking me to go further to evaluate the integration test with ServiceNow.
FYI: i got this notify when request Plugin or login to ServiceNow Store
Hi @ninhnguyen
Maik
ninhnguyen
Thanks @Maik Skoddow @Rahul Priyadars  for you warmly support.
I activated the EventManagement plugin on my instance.
I also tried to follow up some articles but couldn't figure out where/how to start to use it to integrate with connector of Kibana.
I see that ServiceNow support various connectors but not for ITOM connector on Kibana.
https://docs.servicenow.com/bundle/vancouver-it-operations-management/page/product/event-management/...
Could you gimme some glue/advise to start working on it?
Do i need to setup Event Rules, Event Field Mapping or start any other initial steps?
Much appreciated Gents!!!
Maik Skoddow
Hi @ninhnguyen
we are far away from your initial topic of your question, and I would appreciate it if you could mark one of my answers as "Accepted".
Furthermore, I cannot teach you event management via comment threads. I only can recommend taking a look on my page Event Management which provides many links to further resources.
Maik
