How to send notification using flow designer for to and bcc list
Sravani36
Hi All I need a help on the below requirement.
I have created a catalog item "maintenance request" and created one custom table called "Customer notifications". The Variables that are created on the catalog item like lob and customer if the values of this fields matches with the fields that are present in "Customer notifications",it has to check for the record that matches with this 2 fields and trigger the notification.
Here we are creating case with the same flow and then to trigger notification. here I was confused how to take a start.
not possible
I am saying please invoke event from Flow like this and let email trigger based on linked event
https://community.servicenow.com/community?id=community_question&sys_id=8313e10ddb8b1c10f21f5583ca96...
Then in email script you can add CC or BCC
Ankur Bawiskar
you can use lookup record and check on that custom table
You already have the variable values to check using Get Catalog Variables action
When you add filter condition on your custom table select the correct fields and value from the data pill of that variable
whether to send email or not based on matching record can be done in flow designer
for including users in CC or BCC you will have to use email script and notification
regards
Hi Ankur,
I have written mail script how to call that mail script to flow designer
${mail_script:customer_cc_bcc} as it's not workingfind_real_file.png
not possible
