Identification Engine: Discovery status is FAILURE, Identification sections in pattern failed: section: discovery, error: Failed to establish SNMP connection to host (xxxx.xxxx.xxxx.xxxx) Check that host is accessible and correct credentials are def
Ginuix
Mega Expert
Device is discovered. but getting error in discoverey logs
(empty)IP SwitchClassifiedIdentifying
Completed 3
Ginuix
Mega Expert
Hi Everyone,
Thanks for all your input. The provided solution are already check for the reference what we have found.
In windows server some time port exhaustion happen cause this issue in my case.
Best Regards
Gin
Alexey7
Try to increase the mid.snmp.request.timeout parameter of a mid server, restart the mid, and run a quick discovery using that mid server.
Last time I fixed the "same" error by setting mid.snmp.request.timeout to 10000.
Hope this helps.
Ginuix
Mega Expert
Hi Everyone,
Best Regards
Gin
