Modify calculated values in subflow (flow designer) for alert management rule
‎04-13-2022 10:31 AM
‎04-13-2022 11:39 PM
You use an action. To modify the variables from the action you need to modify the action. Therefor you need to open the action. In the flow you can open the action over the button "Open action button". It is in the right corner beside the delete button.
Alternatively you can open it over the home menu of the flow designer in the tab "action".
Please be aware, that this is an OOTB action. So in case you want to modify it, I would suggest to copy it. And then use the copied action in your flow.
I hope that helps.
‎04-14-2022 06:56 AM
‎04-14-2022 07:37 AM
‎04-14-2022 08:11 AM
Thanks!
