Questions/concerns regarding the vCenter Event Collector using only Orchestration (w/o Discovery)
Anders Pr_stega
Hi
I am trying to find a good solution to updating the CMDB with vCenter CI's.
Obviously a near realtime vCenter cmdb update solution is perfect as introduced in the following appealing video (links to 12:15 min/sec)
Ask the Expert : Real-Time CMDB with Ben Yukich
Enabling the Discover vCenter workflow in the platform does not require a Discovery license as I read the following:
Administrators can configure instances with Orchestration to run the Discover vCenter workflow to po...
But - what I can't read is if this mean that we can use the vCenter Event Collector w/o Discovery as long as we have Orchestration? I am not sure if the following text implies a Discovery requirement:
In addition to finding vCenter data through the standard discovery process, Discovery can also updat...
The following link tells me that Discovery adheres to the Identification and Reconciliation framework:
You can control how Discovery handles duplicates using properties installed with Identification and ...
But - I can't find evidence that the inner workings   of the vCenter Event Collector adhere to the Identification & Reconciliation framework too?
Sincirely,
Anders
Look at that! - They obsoleted and deleted it. Apologies.
Looks like the good stuff is in script include VCenterVmStateUpdater.
automation.vcenter events trigger the "Discovery: Process vCenter events" script action which calls VCenterVmStateUpdater.process().
    - Tim.
I'm working on it 🙂
-Anders
Hi Tim
I have enabled the Discovery plugin, but that doesn't bring any new VCenter* script includes to to table (in more that one sense )
This is the script includes starting with VCenter before and after enabling the plugin:
Any suggestions?
-Anders
    - Tim.
Thank you for your help Timothy!
mayank_ihs
We are implementing Vcenter Event collector in our environment to set the hardware status of servers. Like Power ON/OFF.
Are there any specific permissions we need to have on theVcenter side for the events to work ?
Mayank
