What should be the order of running discovery on devices - Network Gear, Vmware vCenter, Servers ?
07-17-2025 03:34 AM
07-18-2025 11:47 PM
@Sumit Das1 Is there any specific reason you want to run in order?
At end, all data will come in CMDB and will relate as it is.
If a tall you need this in Service Mapping, so better idea is first complete the 85% device Discovery and then only go with Service Mapping so that you have all the data in CMDB.
07-21-2025 08:09 AM
Hi @Sumit Das1 ,
step-by-step solution on how to run discovery in ServiceNow — and why the order matters.
1. Why the order matters
Discovery in ServiceNow CMDB builds a dependency tree:
* Network Gear → gives you routers/switches/subnets/IP ranges
* vCenter → gives you virtualization layer and VMs
* Servers → are often discovered later, and mapped properly only if you already have their hosting context (e.g., which ESXi, cluster, etc.)
Correct order ensures relationships like:
* Hosted on
* Runs on
* Depends on
… are built correctly.
1. Network Gear
* Purpose: Discover routers, switches, subnets, and IP connectivity.
* Why first:
* Populates Layer 2 and Layer 3 relationships.
* Helps IP Services to identify which devices are connected.
* Ensures that vCenter and server IPs are reachable and properly mapped.
Run:
* Horizontal Discovery → Network Gear (using SNMP credentials).
2 vCenter (VMware)
* Purpose: Discover vCenters, clusters, ESXi hosts, data stores, resource pools, and VMs.
* Why second:
* Creates the virtualization hierarchy.
* Populates relationships: ESXi → VM → Datastore.
Run:
* VMware pattern discovery (with vCenter credentials).
* This requires vCenter endpoint to be in CMDB or discoverable from network.
3 Servers
* Purpose: Discover OS and installed software on physical and virtual servers.
* Why last:
* Server discovery can now tie discovered virtual machines to the existing VM CIs created from vCenter.
* Populates Runs on::Runs and Hosted on::Hosts relationships correctly.
Run:
* Windows or Unix discovery patterns (with domain/local credentials).
Final checklist:
* Make sure your MID Server is placed properly (network access to all targets).
* Configure and test credentials before discovery.
* Use Discovery Schedules to automate the runs in this order.
* Monitor Discovery Logs & Discovery Status for errors.
* Use CMDB Health Dashboard to validate relationships and completeness.
Please appreciate the efforts of community contributors by marking appropriate response as Mark my Answer Helpful or Accept Solution this may help other community users to follow correct solution in future.
Thank You
AJ - TechTrek with AJ
LinkedIn:- https://www.linkedin.com/in/ajay-kumar-66a91385/
YouTube:- https://www.youtube.com/@learnitomwithaj
ServiceNow Community MVP 2025
