Activity Formatter Help
malu
I found that in one of the threads we can have the activity formatter in the UI page as you can see below
with this script
UI Macro
  1. <?xml version="1.0" encoding="utf-8" ?>
  2. <j:jelly trim="false" xmlns:j="jelly:core" xmlns:g="glide" xmlns:j2="null" xmlns:g2="null">
  3. <link rel="stylesheet" href="/styles/css_includes_ng.cssx"/>
  4. <nav class="navbar navbar-default section_secondary" data-id="991fec850a0006417c9edda2d4e9c487" data-type="section_head">
  5.     <div class="container-fluid">
  6.     <div class="navbar-header">
  7.     <h3 class="form_header">Activity</h3>
  8.     </div>
  9.     <div class="navbar-right">
  10.     <span>
  11.     <button alt="Collapse" title="" class="icon-chevron-right btn btn-icon" tabindex="1" onclick="hideReveal('section'); return false;" data-original-title="Display / Hide"></button>
  12.     </span>
  13.     </div>
  14.     </div>
  15.   </nav>
  16.
  17.   <g:function record_table="REQUIRED" record_id="REQUIRED" />
  18.   <g:activity sys_id="${jvar_record_id}" fields="" table="${jvar_record_table}"
  19. type="changes" var="jvar_activity"/>
  20. <div id="section" class="h-card-wrapper activities-form col-xs-10 col-md-9 col-lg-8 form-field">
  21.     <j:forEach items="${jvar_activity}" var="jvar_history">
  22.     <li class="h-card h-card_md h-card_comments">
  23.     <div class="sn-card-component sn-card-component_first sn-card-component_meta sn-card-component_meta_sibling">
  24.     <span class="sn-card-component-createdby">${jvar_history.get(0).getValue('sys_created_by')}</span>
  25.     </div>
  26.     <div class="sn-card-component sn-card-component_first sn-card-component_meta">
  27.     <span class="sn-card-component-time">
  28.     <div class="date-calendar">${jvar_history.get(0).getValue('sys_created_on')}</div>
  29.     </span>
  30.     </div>
  31.     <g:activity type="labels" records="${jvar_history}" var="jvar_field_labels"/>
  32.
  33.     <div class="sn-card-component sn-card-component_records">
  34.     <div class="sn-widget">
  35.     <ul class="sn-widget-list sn-widget-list-table">
  36.
  37.     <j:forEach items="${jvar_history}" var="jvar_h">
  38.
  39.     <li>
  40.     <span class="sn-widget-list-table-cell">${jvar_h.getValue('fieldname')}</span>
  41.     <span class="sn-widget-list-table-cell">
  42.     <span>${jvar_h.getValue('newvalue')}</span>
  43.     </span>
  44.
  45.     <j:if test="${jvar_h.getValue('oldvalue').trim().toString().length()!=0}">
  46.     <span class="sn-widget-list-table-italic ng-scope">was</span>
  47.     <span class="oldValue">${jvar_h.getValue('oldvalue')}</span>
  48.     </j:if>
  49.     </li>
  50.     </j:forEach>
  51.     </ul>
  52.     </div>
  53.     </div>
  54.     <hr/>
  55.   <div class="sn-card-component_accent-bar sn-card-component_accent-bar_dark">
  56.   </div>
  57. </li>
  58. </j:forEach>
  59. </div>
  60. <script>
  61.   function hideReveal(sectionName) {
  62.   $j("#"+sectionName).toggle("hide");
  63.   $j(".icon-chevron-right").toggleClass("hideBtn");
  64. }
  65. </script>
  66.
  67. <style>
  68. .oldValue{
  69.   padding-left:5px !important;
  70. }
  71. .hideBtn{
  72.   -webkit-transition: -webkit-transform 0.3s;
  73.   -ms-transition: -ms-transform 0.3s;
  74.   transition: transform 0.3s;
  75.   -webkit-transform: rotate(90deg);
  76.   -ms-transform: rotate(90deg);
  77.   transform: rotate(90deg);
  78.   font-size: 18px;
  79. }
  80. </style>
  81. </j:jelly>
IN UI Page
  3. <! record_table holds table name & record_id holds sys_id of record-->
  4. <g:inline template="custom_activity" record_table="incident"   record_id="<SYS ID OF Your Incident>" />
  5. </j:jelly>
This will show us the activity in a separate UI page , BUT when iam trying to change the code for the below activity formatter it is coming in my UI Page. Any Help
Any Help on this?
12 REPLIES 12
malu
Thanks Gurpreet i will try to modify.
One minor ask is that these Baseline difference is a formatter kind of i can't find the fieldname for it. Do you know where to check on that?
Gurpreet07
Like if you want to make a check for comments then include a condition for backend name of comments ... ideally it should be u_comments.
malu
Thanks Gurpreet.. I think you mistaken the requirement i need.
1.There is a field called Comments in UI page ( text/area ).
2. Now in computers table there is a CMDB Baseline Diff is there , this gives us the difference in CI (any changes) made from the time of Baseline created auto populated in dropdown.
3. I want to pull this difference data whether it is a attribute change or relationship change we need to pull these information into the comments fields in UI page.
