‎06-02-2015 12:21 PM
I'm seeing an issue with the fields that are appearing in the UI14 Activity Stream (on Eureka Patch 7).
For example:
- We are using [task].[state] (labeled "Status") on Incidents, so we have customized the Activity Section formatter to display changes to that field.
- However, the Activity Stream is only displaying changes to [incident].[incident_state] (labeled "Incident state").
The Wiki leads me to believe that the Activity Stream should pull whatever fields you've configured for your Activity Section: http://wiki.servicenow.com/index.php?title=Using_Lists#Displaying_Activity_Streams
Does anyone know exactly how the system determines which fields to include in the Activity Stream?
‎06-25-2015 03:11 PM
In Fuji there are various System Properties such as glide.ui.change_request_activity.fields, glide.ui.incident_activity.fields, etc.
One for each table relevant to Activity formatters/streams. Maybe in Eureka the Activity Stream doesn't use these properties, but in Eureka it does. I'm on Fuji and the stream matches the formatters.
‎06-10-2015 09:42 AM
Hakan, just to confirm, are you talking about the "Activity Formatter" for a table that is displayed on a single record's form view?
My issue is with the newer "Activity Stream" that shows in a list view, so I want to make sure we're not talking about two different things. (I'm also open to suggestions of clearer/more correct terms for both of those concepts, hah.)
‎06-09-2015 02:21 PM
I have noticed the same problem on our custom tables - the Activity Stream doesn't show ANYTHING - it's completely blank, even when there is an activity formatter on the form. I did try Hakan's idea about un-checking/re-checking the "All" box in the activity formatter filter, but it didn't seem to help.
It seems to work correctly on Task tables - it will show exactly what the formatter shows, even if the formatter is filtered.
What a head scratcher!
‎06-10-2015 09:45 AM
Patrick, just to confirm, are you saying you don't see the issue I'm having when looking at the list-view Activity Stream of tables extended from [task]?
If you're only having issues with the Activity Stream for your custom tables, then you may be one step ahead of me!
‎06-10-2015 09:54 AM
That's right. On Task tables, the activity stream only shows what the activity formatter shows in BOTH the form and list views, which is the desired behavior, I think.
If I open the activity stream on a custom, non-Task table, the activity stream is completely empty, even if there is an activity formatter on the form. In the list view, I get a "Record activity will appear here" message.
On the form, and on the list:
‎06-15-2015 02:44 PM
Ooh, yours looks fancier than mine. Are you on Fuji?
