Add KB Article link in notification
Priya75
I want to fetch the Kb article number from incident ,So there is a filed on incident form as  u_knowledge which saves trhe kb article number. i want to give the link of that particular KB article in portal view from the notification.
Ankur Bawiskar
Hi Priya,
you need to use mail script for this
Include it in notification like this
${mail_script:show_kb_link}
Script:
Note: Ensure you use valid query based on whether u_knowledge is reference type or string type
(function runMailScript(current, template, email, email_action, event) {
	var KbNumber = current.u_knowledge;
    var kbRecord = new GlideRecord('kb_knowledge');
    kbRecord.addQuery('number', KbNumber); // if KbNumber stores number
	// OR
	kbRecord.addQuery('sys_id', KbNumber); // if KbNumber stores sys_id
    kbRecord.query();
    if(kbRecord.next()) {
	// this would take user to portal
    var url = '/sp?id=kb_article&sys_id=' + kbRecord.sys_id + 'table=kb_knowledge';
    template.print('<a href="' + url + '">' + kbRecord.number + '</a>');
})(current, template, email, email_action, event);
it is not working.i am not getting any link in the notification
Hi Priya,
u_knowledge is reference to kb_knowledge or string which stores KB number
you need to use proper query accordingly
 yes i have used the sys_id one, it redirect one but it takes me to the portal but knowledge article record is not displayed .
Hi Priya,
so to which page it is taking?
