Approval is not required
Dialy
Mega Contributor
My name is dialy gningue,i hope you will find a solution to my problem.
we’re working  on  sub-prod instances (dev and QA) and we are currently working on change management application, and for some reasons that are still unknown, on changes approvals on approvers section, it display :  « No Longer Required » next to each approvals. approval should be required any time. We’re using a approval coordinator activitie  in the workflow to manage all approvals.You can see the Screenshot for a better understanding. do you have any idea how we could solve this ? Tkanksfind_real_file.png
Dialy
Mega Contributor
hi every one,
i found my issue, it was a BR that changed the value of the state field of approvals to false, it was based on several condition and unfortunately approvals for approval coordinator activities were part of.
Thanks all for The involvement.
16 REPLIES 16
Can you please post the BR name?
Daiki2
Giga Contributor
hi every one,
I'm currently facing that problem too.
I would like to know the name of BR.
